Changing a Cylinderhead gasket
Steptoe
Him/Bloke/Fella.
S/W London.
Changing a cylinder head gasket.
The pictures are an 1100 GS, but the only difference between the 1100 & 1150 is in the exhaust down pipe fixings to the cylinder head –
The 1100 have three bolts per side (that are normally seized and you can guarantee at least one will snap off), and the 1150 have only two per side, that you shouldn’t have any problem removing.
You don’t have to remove the tank, or any other bodywork, but I’d suggest spraying penetrating oil or something similar onto the exhaust bolts a few days before. Also have a new set of exhaust studs and nuts to hand.
The exhaust bolts. If they’re badly corroded and flaking, hit a smaller seized socket onto them. The socket size depends on how badly corroded the nuts are. Start with a 13mm, then work your way down to a 11mm if need be.
Here’s one that snapped.
You have to remove both downpipes on an 1100, and you can get away with only removing one side on an 1150, but you’ll find it so much easier taking both off.
I use an old broken airhead exhaust spanner to knock the pipes out of the head.
Here’s the head with the down pipes removed.
All the work shown, is being done on the right had cylinder head. It’s all the same as the left hand except the cam chain tensioned is on the bottom on the right hand side, but on the top on the left hand side.
Remove the throttle body from the head.
Remove the rocker covers, and get the side your working on to TDC. Remove the cam sprocket cover.
Put the bike in gear, hold the rear brake on, and crack the sprocket cap nut loose (don’t undo it more than a turn), it’s an 8mm allen head bolt
Now the important part.
Thread a small cable tie through a hole in the sprocket, and around the timing chain. Remember, you’ve loosened the sprocket, so you can move it away slightly from the head, giving you some space to get the cable tie out from behind the sprocket.
Pull the cable tie tight, so the chain can’t fall from the sprocket.
Now remove the two lower allen headed bolts ( 5 mm heads)
And remove the four cylinder head bolts ( 15mm hex head) . Three are obvious.
And one partly hidden underneath
Looking near the cam sprocket, you’ll see a an allen bolt, this also need to be removed ( 8mm head) .
Bolt removed
Now remove the cam sprocket bolt completly.
And undo and remove the cam chain tensioner ( underneath the cylinder)
Pop the sprocket off the cam end, and looking down where the cam chain goes, you’ll see a small allen head bolt
You need the sprocket off to allow you to undo the small allen bolt , which is a 5mm head. And you’ll need an extension bar as shown.
That’s all the bolts removed that hold the head in place - you’ve no need to remove any of the bolts that hold the rocker gear in place. They all stay in place on the head.
Now you just pull the head off, it may need a bit of gentle persuasion with a rubber hammer type object ; ) .
Taking care that the cam sprocket goes down the tunnel as you remove the head
And what it should look like when the heads removed .
Clean the surfaces of any old gaskets and dirt.
The new gasket is 3 layered, they’ve been like this since 98, so if your replacing an earlier model, don’t worry if it’s different to the one you’ve taken off .
Place the new gasket onto the cylinder.
And fit the head back onto the studs, making sure the cam sprocket and chain is pulled through the head. Do the cylinder head nuts and all the other bolts up to the correct torque.
Now the fiddly bit, and the part that needs to be done correctly or else you’ll have a bike that woun’t start, or worse, an expensive bill .
On the cam, you’ll notice an index slot. This can be moved a few degrees either way, don’t worry if it moves, it’s not going to alter the valve timing.
And on the sprocket, you’ll see the locating tab (shown in the pictures before the head went back on,so it could be seen clearly.
Now, you’ve got to locate the sprocket onto the cam, with the tab fitting into the index slot. You can move the cam a small amount to kelp locate it. THAT’S WHY WE CABLE TIED THE CHAIN TO THE SPROCKET. So the valve timing will be the same.
When it’s fully located in place (take your time and make completely sure it all located and in place properly), do the sprocket nut up finger tight and cut off the cable tie. And replace the cam chain tensioner.
NOW TURN THE ENGINE OVER BY HAND, ( with the bike in gear, turn the back wheel to revolve the engine). Try doing the same before starting the job, so you’ll know what it feels like, and have something to compare.
It should turn the same as before you started the job.
If it doesn’t turn fully, and you can’t turn the engine, it means you haven’t located the sprocket onto the cam properly.
Just turn the engine back to TDC, cable tie the chain to the sprocket and try again until it's right . But if you can’t turn the engine over by hand don’t even think about starting it up. Just keep on locating the cam and sprocket until you can
The job is now done, you’ve just to replace all the parts removed and check the valve clearences .
If you’ve snapped a couple of exhaust studs, don’t worry , they’re lots of bikes out there riding around with only one stud on each side, and they don’t have any problems .
neil, you have a gift for technical writing ( and pics). Almost gives me the feeling i could do the job myself!
Hi Steptoe (Neil),
Thankyou for your detailed pics and description for the head
gasket change, me thinks that will be my next job after the tank sender is sorted !
As I have still to determine my oil leak it looks like first of the three five mm bolts
is the leak but impossible to be certain.
As I posted before the former owner had the head gasket replaced and oil seeps out so my only way forward is take it off again.
I take it you leave the studs as is as extraction merely strips the alloy thread.
Many thanks for the info Regards Mack... :)
Thanks Neil, hope you don't mind, but can I stress just how important it is to align the sprocket tab. If you get the alignment of the sprocket on the camshaft slightly out, i.e. sprocket tab not in the cut-out of the cam shaft, the tab will crush down on the cam shaft just fine, all will seem fine until you start it. If it’s just a little out, the throttle bodies won’t balance up properly, you might get horrendous vibration and sooting of the affected side (and low compression if you measure it), if it’s far enough out, it will likely bend valves. :(
And no, I didn’t do it, I was just involved in fixing it,and it DID take some fixing! :confused:
Hi Steptoe,
Can you give me the correct size for the cylinder head nuts ?
I thought they were fifteen mm my socket just nicks them, are they fourteen
point five.
Many thanks Mack.....
Hi Steptoe,
Correction the sound I heard was in fact the nuts coming undone
very weird sound as if jumping of nut, I have got them off with fifteen mil
ring spanner. my gasted is flabbered !! very strange sound ...
Regards Mack..... :)
Hi guys - I've got a 1997 R1100GS that after riding some 1700 odd miles in one weekend (I was a competitor in the Iron Butt Association Brit Butt Rally !) has started leaking oil on the lefthand cylinder. From what I can see it seems to be leaking from the engine/cylinder joint.
Having read this excellent thread, is it just a case of undoing the cylinder bolts and removing the cylinder so I can apply some sealant to stop the leak?
According to the Haynes manual I should use "3 bond 1209" - any idea what this is, or can I use Blue Hylomar?
Shaun
IBA #40051
Help please
Hi guys - just bumping this thread as I urgently need to sort out the oil leak as I'm hoping to do a 2000 mile round trip via Lands End to John O'Groats next week !
Shaun
IBA #40051
Just found this thread. Great Can someone tell me he torque for the 5mm and 8mm Llen head bolts? Thanks
You should really be using a manual if you're going to do a job like this (especially for torques etc). Clymer and Haynes publish decent manuals.
However, you can download the factory manual from here:
http://www.carlsalter.com/motorcycle-manuals.asp
bear in mind that it makes some assumptions as to skill levels and glosses over some of the simpler tasks but it should get you going.
Thats for the joint tween the block and cylinder
You just replace the head gasket and retorque if is leaking there
A good quality RTV silicone sealant will sort the base seal
Shaun
IBA #40051
.....factory manual from here:
Thanks. I'm to the point that I have the rocker cover off. I've got the piston to TDC. I want to undo the cam sprocket cap nut, but everytime I go to do this (even with the rear brake on and the bike in gear) the "OT" timing mark moves out of sight. I take it that this is okay as long as I just crack the bolt then rotate the crank back to TDC then undo the bolt by one turn to get enough play to get the plastic tie around the chain and sprocket. Is that the case? TIA.
Make sure you have the bike in top gear to give yourself the best mechanical advantage. As you say, if it does move just turn it back with the bolt just cracked loose and finger tight. Then follow Steptoe's instructions in this thread - yes, just undo the bolt enough to get the tie around the chain and sprocket.
When removing the bolt, be aware that there's a thick spacer / washer between the bolt head and sprocket. The first time I did this on my bike this spacer was stuck to the sprocket (I didn't realise it was a separate item) and I nearly dropped it down the camchain tunnel :eek
When refitting, pay careful attention to the advice regarding the keyway on the sprocket.
I've just read this with interest as I've bought a 2000 R1150 GS and managed to snap one of the exhaust studs whilst removing the exhaust. :blast Are you saying that it will still be fine without removing and replacing the stud? Will the exhaust not blow?
Thanks.
Carbon on valve
Just in middle of this job , can I clean the valve heads ? One has slight carbon on it , other wise all in great shape , Thanks in advance .
Thanks.
THE VERY best way to avoid broken studs is to heat the nuts before trying to turn them. A gas welding torch is probably the best, but arc weld is a very good second. For all the hassle it saves a cheapo set from Aldi is good enough. A normal plumbers torch is not fine or hot enough to have any useful effect.
HOWEVER - ALWAYS disconnect all cable connections to the engine and disconnect the battery before arc welding. Forget and something expensive will fry just as happened on Long Way Round, but the same rule applies for all cars and bikes.
Its initially a bit more hassle (and dont weld so much the spanner wont fit) but its 100x easier than having to drill out broken studs.
When done use stainless dome nuts to keep the threads clean.
Forget and something expensive will fry just as happened on Long Way Round, .
That isn't exactly true. ;)
Servo brakes depend on brake switch wiring - wiring gets hot near the weld point, etc etc :D
