Had a few days leave booked this week to get out and have a good play with the bike before the roads fill up once the good weather comes.
Put some Nippy Normans bar risers on this morning and decided to go out to the coast (well Weston Super Mare actually) and see what difference they made.
Coming out of WSM approaching a roundabout I started to brake as the large white van in front was stopping. NO BRAKES. FEEEEEEECK! I have the ABS with servo and it was just like turning the ignition off. Coasted to a very hairy stop coming up a couple of feet short of the vans rear end.
Red warning light came on during no brake episode but then went off straight away. Headed off, very gingerly, to Bath Road BMW in Bristol to see if the could have a look and decide what the problem was. Half an hour before the main failure the brake the brake warning light came on for a second and then went off. I did test out the brakes on a number of occasions but as I was as far away as I intended to go there was nothing I could do but return home not thinking there was a major problem on its way.
On arriving at Bath Road BMW (at 4:00PM) and even with a couple of their staff on their hols they couldn't have been more helpful. It went straight on the ramp and they did a diagnostic check. Before the computor check, it appeared that when the rear brake pedal was depressed the servo unit didn't turn off even after letting go. It turned off when you pressed the handlebar brake.
The printout after the diagnostic check had 4 errors. Now they have to speak to someone at BMW
to find out what the error codes are as they're not sure if it's the same problem repeated 4 times OR 4 seperate problems.
Unfortunately they can't fit the bike in for work until the 11th April although they did suggest I could try Ocean in Plymouth to see if they could do the work sooner but that would mean riding a bike with suspect brakes for a 2 hour ride down there! They also said they might need the bike for a few days (suggestion of replacing the servo unit) so I'm getting nervous that I won't be able to make Land's End.
It certainly was a hairy moment and a wake up call but at least there was no damage and the bike is fortunately still under warranty.
Now I'll have to cancel the rest of my leave as there's no point staying home with the bike in the garage and not being able to play.
BUGGER!!
Steve B
to find out what the error codes are as they're not sure if it's the same problem repeated 4 times OR 4 seperate problems.Unfortunately they can't fit the bike in for work until the 11th April although they did suggest I could try Ocean in Plymouth to see if they could do the work sooner but that would mean riding a bike with suspect brakes for a 2 hour ride down there! They also said they might need the bike for a few days (suggestion of replacing the servo unit) so I'm getting nervous that I won't be able to make Land's End.
BUGGER!!
Steve B
