Indian and it's still a no on them.In fill panels.Or is that the Indian?
I forget.
Well I might aswell just do it then. Is it a big job ? I don't mind spending the money but I don't want to get ripped off either.Seriously, if it’s a workshop you trust, ask them to look at your compensator whilst it’s in the shop….
In terms of labour? Not really. I suppose an hours labour. Drain case, remove outer cover, remove tensioner, remove the whole assembly (clutch/comp/chain) inspect, install in reverse. Just ask your dealer/service guy to quote. Knowing what’s involved should help you consider the cost of his quote. You can get a feel for the cost of gasket from the link someone posted recently. If it’s ok, you’re good to go, if it’s not, look at the options for replacement in advance?Well I might aswell just do it then. Is it a big job ? I don't mind spending the money but I don't want to get ripped off either.
Maybe 2nd city again![]()
Is it easier for me to buy the compensator ?In terms of labour? Not really. I suppose an hours labour. Drain case, remove outer cover, remove tensioner, remove the whole assembly (clutch/comp/chain) inspect, install in reverse. Just ask your dealer/service guy to quote. Knowing what’s involved should help you consider the cost of his quote. You can get a feel for the cost of gasket from the link someone posted recently. If it’s ok, you’re good to go, if it’s not, look at the options for replacement in advance?
Plus the compensatorGasket kits about £65..
I'd best get saving up or probably easier to get a new bike.And Labour and primary oil
See you tomorrow.I’ll give you £7k for the RKS… cash , make it easy
Only if it’s goosed….Plus the compensator
He’ll be having a service anyway, so oil (and no doubt they’ll charge for a clutch cover seal too) will already be accounted for…And Labour and primary oil
Let’s hope not… it’s mine after tomorrowOnly if it’s goosed….
Wait till he’s got the Police seat fitted….Let’s hope not… it’s mine after tomorrow
