Sold 1000 l IBC watercontainer
albatross
Cheshire
1000 Litre IBC - White - Plastic Pallet​
Has been washed out prior to me buying..had only teats disinfectant stored, so safe to use for water collection.
I throw in a algae protection cover..
Surplus to requirements
Might be able to help with transport within a 30 ml radius Nantwich
PM me if interested
Want £60- PPFF or cash 4FFD0B76-8B73-4A95-8117-2B8DBF6CE198.jpegDC2B230E-1BFB-42ED-8016-86C9F862BCF5.jpeg337B5240-6383-463C-B907-524884ECC53F.jpeg
Bump and reduced to £ 50.-
Can help with transport, reasonable distance…CW5
That's a really decent price for an IBC - We have got 3 of them for storing/drying firewood in - they are great pieces of kit. The tank itself has been chopped in half to make a cover for the wood as it dries.....
Free bump - alternative use included
As another alternative use, and if you happen to have a pallet truck or forklift, cut the top off and fill it full of rubble and use it as an anti ram guard for roller shutters or gates.
Warm season is on our doorstep….all you gardeners, allotment owners and bike and car washers…
Here’s your chance to own a massive water tank on a plastic pallet…never worry about water charges again..
Harvest your own and use your own H2O……:::))
These things are normally a standard size to allow for stacking and easy transportation inside the cage, and according to google, they should be 1000mm wide, 1200mm deep and 1163mm tall.
It may allow you to get a rough idea before the Albatross comes back to you?
I’ve got 1100 mm entry height into back of the van, Citroen berlingo
Here we go Mikey
Length 122 cm
Width 101 cm
Height 116.5 cm
All +/- 1 cm
It sits on this plastic Euro palette
Any queries drop me a line
Fingers crossed Albatross can put a straight edge over the top and physically measure the drop to the floor for you?
Don't need to do that as the cage is straight at the top , it’s a rectangle 122 x 101 x 116.5 cm within the cage.
