Not my bike. Currently replacing mate's 1999 R1100GS'es clutch that got slippy when we returned from Syria/Jordan and in Greece, where we rode around 140-160kph (90-100mph) speeds on the mountain roads going on full throttle (bikes were fully loaded) on the steep climes or accelerating out of curves he noticed a clutch slip.
Also later the clutch stared to make noises (a "loose" pressure spring coz of no counterpressure from the worn clutch disc?) as it wore out more. It got worse by the day, but his trusty 1100 still got him home over 2000km away, safely.
He's bike is at 60Kkm (40K miles), so I reckon it's a premature death for the oilhead clutch(?)
One of the suspicions - see the oil marks on the clutch plate going out. First we thought is was a grease from the shaft's teeth, but it was too viscous for the grease.
Another pic of the suspected small oil appearance on the clutch plates.
The pressure spring looked OK.
Except that spot, looks like something has dragged it, but it turned out to be a grease.
Clutch plate, any more aknowledged guys can rate the colour of the material? Is it soaked with oil or is it OK?
...until we spotted this! We put the gearbox on the ground with a small angle leaning forward and a gulp of TRANSMISSION OIL came out of the input shaft's hole (where the clutch rod operates).
The very suspicious oily input shaft...
MOST of the transmission oil was "trapped" on the other side of the input shaft, into the clutch arm's rubber sleeve.
Very oily sleeve - the smell was unmistakable - transmission oil!
So this is our current theory - the leak is from the input shafts other end's taper roller bearing race. Anyone can confirm?
Another pic...
Looks like a very rare problem? I have heard engine's output shaft blowing up causing a oily-slippy clutch. But oil coming from transmission side seems to be a very rare case(?)
With engine oil leaks through output seal, it's usually excessive and you would see the oil marks on the clutch casing etc.
Ours was relatively clean, but some spots were oily and I reckon few drops of the transmission oil on the clutch plate was enough to make it slippy.
The oil leak from the transmission side apparently is very small and slow. There was just a small (but serious) gulp of oil in the clutch arm's sleeve.
So the main question is: how to make the leak stop? Apparently there is no seal on the other end of the gearbox'es input shaft. It's just a taper roller bearing capped with race from the other end. The race is supposed to work as a seal? If so, looks like the only way to replace the bearing race is to completely open the gearbox(?)
What do you tech guys reckon?
Thanks in advance, Margus
Another pic...
