1100 + MRA screen + GPS?
MattW
Cheshire
I've just picked up a Garmin 2720 and I'm looking for some ideas from those who have an 1100 with an MRA screen and a satnav / gps.
Where do you mount your stanav (and what mounting hardware do you use)?
I'd have preferred to mount it above the clocks, but the profile of the screen means that there's no room for the satnav (the screen almost touches the clocks).
Any ideas appreciated!
I used a Migsel mount but have since put it back on the handle bars using a Ram arm etc ..
GPS
Got a stainless pipe and bent it to shape put some lugs on it and fastened to MRA screen bolts. Perfect position but has a bit of movement , will need to shorten the arm I think.
Broko
Broko
Neat :thumb2
I ended up with a fairly standard 'RAM mount onto the left bar' setup - works quite nicely and doesn't obscure anything. Yours is much better though - I like the way its in your line of sight - as you say a shorter arm (or no arm even?) would be perfect.
