1100gs forks
finn
Chester
Need to consider upgrading my forks anyone done it or what fits mainly for off road
Tia
Sent from my VOG-L09 using Tapatalk
Is it not the damper that does most of the work?
Got a new spring on but am finding the limits
Happy to be corrected but I don’t think the forks do much in the way of affecting the ability of the suspension. Maybe a rebuild on the damper would yield better results or an aftermarket job, such as the Wilbers that were advertised on here, sadly I think they were for a GSA.
Tia
Do you know how the front suspension/steering on an 1100/1150/1200 actually works ? Go have a close look.
All the forks do on an 1100/1150 is attach the handlebars to the front wheel. Hence why there are no fork "upgrades".
If you fitted forks that operated in the same manner as a "normal" bike they'd be fighting against the bmw front shock.
There are bikes with the front telelever removed and upside down forks fitted but that requires an entirely new front subframe especially made, and believe me, i've ridden one, it's not an improvement on the bmw setup, it's a backward step. .
Yep had a good look about over the weekend and upgrading the springs and front shock is the way to go
Here's the subframe required if you want to get rid of the telever and use conventional fork.
Cheers will try upgrading the springy front shock before I go that far have to remember the bike and riders capability
