45grum
Hi all
After years of bikes of all sorts including several airheads and a K100 I have gone and bought a 1100GS it is a Jap import 94 model in red with about 30K on the clock it seems to go alright but i have a few questions need answering. Jap models dont have the fuel gauge so i would like to know how much is in the tank when the light comes on ( how many litres/miles have i got left ). The bike seems to lean over to far when on the side stand is this normal as it does not seem to be worn much? also the indicators seem to flash very fast ( is the relay the wrong one ).
There are a couple of things need sorting like one bar end weight is missing, also one injector cover, the right hand plastic cover below the tank both mounting lags are broken off. also the rear wheel rim is heavily soiled it does not appear to be finished with anything. The bike has a plastic fuel tank which someone said should have been changed as they tended to leak, was this a factory recall or on a if it leaks we will replace it basis?
I look forward to any replies.
Cheers Graham
Cheers Graham
