iilias1972
the bike r 1150 gs 2001 single spark with 99000 km. Probably the old lady wants presents for her 100k
Issues at latest months...
High consumption about 9-10 l/100km.
Smell of fuel.
Starting difficult. Starting with fast idle. Must have pulled fast idle (first level) at least the temp goes to 1 or 2 bars.
Yesterday after 15km ride the idle goes to 1400rpm. After a 20minute stop the idle goes to normal (about 1000 - 1100 rpm) but the bike break down at every stop light. This happen from 3 bars temp and continues at 5 bars temp.
Before this i have check the throttles balance and they was perfectly balanced. Tps at 0.37. Plugs of oil temp sensor, air sensor, lambda sensor looks good and i put in then a little dielectric grease.
Five days ago i check and clean the injectors. Then i noticed the fuel dont stop leak from the injectors base. Is this normal? I dont remember if this happen years ago when i have pull out the injectors.
Spark plugs and fuel filter 1000 km before.
Coil and spark plug cables 5000km before.
Lambda sensor 10000 km before. Bosch with the same length and plug.
Fuel pump 10000 km before.(not original).
Hall Effect Sensor 15000 km before.
Sorry for my English.
Any suggestions for the problems?
thanks!
Smell of fuel.
thanks!
