1150 Clutch lever "heaviness"
Sweaty Sock
Powys, Wales
The clutch on my bike works fine. In fact the gear change is pretty good for a 1150. :okay
Perhaps because I've got this persistent tennis/golfer's elbow I am finding the clutch a bit heavy. Compared with my old VFR it is heavy.
Wondering if this is common as a couple of folk have told me, and if there's something I can do to lighten it? Due a fluid change, not that it ought to make much difference. Should I venture into the actuating rod unit and grease it up? :eek:
Have you lubed the pivot bolt? I replaced the pivot due to wear and play but I don't recall it leading to heavier action.
I hope your problem isn't at the other end.
