1150 GSA and RoxSpeed 2" handlebar Risers
TangibleSolid
Member
Sheffield, England
Hi,
I'm looking to get some RoxSpeed 2" handlebar risers like these.. on my 1150GSA
Does anyone have any experience of the product and specifically will they fit without extending cables, pipes and wiring?
I like the look and the potential for adjustability but I don't want to shell out for them and then find that I need to 'invest' lots more ££ to get them on the bike.
any first hand experience or advice anyone??
Cheers :beerjug:
I know we don't like using phones anymore.......but
Try asking the suppliers, they are quite helpful.:nenau
And they should fit without modification IMO.
Appreciate the reply,
I've spoken to the supplier and they think it'll be "do-able, but might be tight", so not really conclusive!
I was hoping that someone on here might have actually done it and could confirm one way or t'other
Also the supplier suggested that it might be different (easier or not) between an ABS and non-ABS bike. Mine is ABS but:nenau
You get forward and rearward adjustment of the handlebars as well, to suit your riding style this will determine if you need to lengthen the cables et al, most folks move the bars to suit their comfort, that comfort v cable adjustment v all = you decide - most are happy with the result without further change
Go for it, they are a popular solution to many issues regarding comfort :thumb2
Should they not suit sir, then I'll be quite happy to give you a tenner posted.:D:D:D
Yeap got a set on mine and they are fine.no probs with cables at all just cut and rezip tie loom a bit.
Shut up you two, got him dangling, then almost had the bloke selling me one for a tenner. I dunno:D
Anyone got some rox risers FS......... cheap to a good home:bounce1
Don't mean to hijack but.....
What if any bar risers can you fit to a 1150 GSA without having to worry about brake cable and wiring length adjustments ?
Hi folks,
Regarding my original question re roxsport risers on my gsa,
Thanks for your replys, based on actual experience (thanks spa1403 and chad) I think I'll give it a go.
Flatdog - thanks for your generous offer, if it all goes tits up I'll certainly consider it. (Although not for long):thumb
Hi folks,
you wont have any issue's here's a set of Rox anti vibe risers on top of 20mm risers so nigh on 2.5" only thing you will have to do is cut some cable ties then re tidy them:thumby:
alternatively you could get yourself as set of hens teeth like ive got on my latest:D:D:friday
