1150 GSA seat extension help
MR&MRS.P
Warrington
Hi folks
Bought a seat extension from a fellow Tosser, problem is when its fitted I can't install (or remove) the seat. Am I missing a trick or something???
There is about 30mm of overlap...
You might find you just have to force the seat past the padding of the extension piece. It's a tight fit...
But if the base of the extension is overhanging 30mm i'd question if you've fitted it correctly? Though i would have thought it was relatively straight forward? :nenau
