Repoman
Hello all, havent posted for a while so good to be back....
For various reasons I havent used my GS regularly for the past couple of years but it has been serviced, MOTed and kept in the garage. I have also used the Optimate, albeit sporadically.
A few months ago I had starting problems which I think was down to the battery expiring (03 bike on original battery) so I replaced it with a new one from BMW and everything seemed tickety boo. I've used the bike maybe half a dozen times since with no problems.
This morning I got the bike out to go to work and it started fine. I let it warm up and then turned it off while I shut the garage door. Went to restart it and.........grind, grind.... the starter realy struggled to turn the engine over and it wouldnt start. Grind, grind, grind, and then takka-takka-takka clicking noise. Rats.
Put the bike back in the garage, put the battery on charge and went to work on the Lambretta (flawless of course: 48 year old Italian shopping bike technology).
Came home tonight, Optimate showing full charge on the battery, good. Bike starts first time, fine. Run it work a couple of minutes and switch off. go to restart it and.......Grrrrrrr! exactly the same as this morning. takka-takka-tak
Obliged if someone could offer a diagnosis as I'm a bit stumped. My provisional and very amateur diagnoses are -
New battery shagged as well.
Battery not recharging?
Starter motor shagged in some way (but why would it start first time?)
I concede that the bike has had irregular use but it has been fine the past few times I've ridden it.
So, finest minds in GSerland please come to my aid...
