Right been tied up at work for last 2 weeks so go to start bike ,starts first time and the revs pick up when I give it some throttle ,,,,,,bingo ,,,,take bike onto the road put it in gear won't pull away nothing.starts again revs ok put it in gear won't pull away and splutters and stalls . Is this what will happen if it's the hall sensor or is there any other sensor which may be the problem cheers steve
Doesn't fit the classic 'hall sensor' symptoms but it doesn't rule it out either sadly. If it is happening only under load and revving freely otherwise you may need to start from scratch and rule out fuel/ignition issues first. Or there maybe someone in your area that can lend you one to help rule it out?
