1150GS handlebars?
Possu
Oxford, England
Collecting my 1150GS in just over a week. When test riding the bike, first thing I noticed is that the bars seemed quite high? I'm 5'10" & the seat is standard.
Can I fit regular Renthal bars with a crossbar & a lower bend as a straight swap or would I be better off getting risers & Pro-tapers of some sort (with a very low bend) & doing away with the cross brace?
Thanks in advance
Steve
If it's a second hand buy, are you sure it hasn't got risers on already? At 5'10" you shouldn't find em too high, if you've come off of something sporty give yourself chance to get used to the different bar/seat/peg configuration, you may well find yourself going higher.
The bmw "rockster" bars should be a straight swap and are very flat.
Tobers has got standard R1150 bars on his GS and may know more about swapsies..?
:moped:
:moped:
A friend has Rockster bars on his GSA, I'll try it out. I quite fancied something like this: http://shop.verholen.de/ I've e-mailed them to see when a 28mm version will be available to suit Pro tapers. If & when I get a reply, I'll post the answer here.
Anyone know of a similar product available now?
Steve
I think the bars need to have some height to clear the tank on full lock. Lower them & you might end up trapping your thumbs.
As for getting rid of the crossbrace, I find it really useful to mount a MX type bag & my GPS on there so wouldn't want to be without it. I think MM/man has a point - try it for a while as it may just be something to get used to.
HTH,
I have R1150R bars on mine due to the doorway I need to get the bike thru'. The bars are £90 new from a dealer.
People who have ridden the bike find it OK and I now prefer this to the standard GS bars. I have put bar risers on it to raise the bars 35mm.
Combined with the (larger than standard) Wunderlich screen with Tobinators the position seems perfect for my (6ft 1) frame and allows effortless 90mph cruising for as long as the petrol lasts.
The only downside is no cross brace, but then I have no GPS. Also, can't fit the BMW handguards, but there again I have heated grips.
Incidently, the dealer who fitted them said they were a bugger to fit and took nearly 3 hours - don't know why......
6X
Yes indeed - I fitted Rockster bars as I found the standard bars just too wide for filtering through traffic.
I'd be very cautious about fitting non BMW bars just because of the way the grips, bar ends and heated wires etc fit on. With the Rockster bars, everything bolts straight on so you dont need to drill any holes or anything like that. The exception is Ricky's bars which are provided all ready to go with the correct fittings.
The main difference of the Rockster bars is about 6" narrower, a slightly more forward riding position, and your hands are at less of an angle to the straight-ahead position.
It also makes the whole bike feel much more compact and chuckable. The whole bike feels smaller. Definitely one of the best mods I made to my bike.
The downside is that you lose a slight bit of leverage at the bars but I stopped noticing this after about a day.
The bars are about £90 from your friendly BMW dealer.
Fitting tips: The grips and fluid reservoirs are awkward to remove, with many hidden screws all of which have different screw heads, sizes etc. The most awkward screws are hidden under the inner end of the grips and had me confused for ages while I tried to find them. There are also some screws inside the holes that the mirrors go into. Take care not to let the bars flop upsidedown resulting in the fluid reservoirs leaking everywhere or getting air into the brake lines. When removing the grips (assuming they are heated), FIRST unplug the wires at the end where they are connected to the loom just under the front of the petrol tank. You'll need to slide the petrol tank back a bit to do this by unbolting the bolt on the lower right side of the tank behind the plastic cover. As you remove the grips by sliding them off the bars, you need to feed the wires through the hole in the bars, making sure the end connector blocks dont get caught on the hole like mine did.
When re-fitting, you need to feed the wire back into the new bars and use a bent bit of wire (paperclip) to grab the end and pull it through the little hole in the bars. You'll find that the hand guards are a tight fit as they are now fitting onto the angle where the bars bend downwards. A bit of perseverence will sort this out no problem - just make sure you get the cable routing so the bars turn freely. Dont forget to put all the myriad of little screws back into the right places!
It took me about 3 hours to finish the job, most of which was spent trying to work out where all the bloody screws holding the grip assemblies were hiding.
By the way, when refitting the throttle tube/grip, put some grease on it so it is nicely lubed against the handlebar. That way, your bike will feel much faster as the throttle action will be smoother and require less effort. Small things like this make a lot of difference.
I've just been in an email discussion with one of our bretheren and I've realised that I may have made an invalid assumption. The bars I had are R1150R bars, but I just assumed that they were the same as Rockster bars as I'm sure at some point I looked at a Rockster (just a sideways glance you understand, nothing more) and it had the same bars on.
So all my above drivel is related to R1150R bars and nothing whatsoever to do with Rockster bars, unless of course the two are one and the same.
Tobers,
Have you changed the bars on the R1200GS? In my opinion the bars are too high and too wide.
Do you know if the best bet is to go for BMW bars, or will the Renthal FatBars that I bought for the experiment work?
At ninety squids I don't think it's that bad... Paid sixty squids for the other bars...
Tobers - thankyou for the timely post! I have a set of R1150R bars sat on my bench ready to fit to my 1100GS, for just the same reason; to gain a bit of extra squeezability through Londons lovely traffic, and get my head down a bit for the M1.
Those pointers will come in handy.
I've put the job off for the last 2 weekends once I spotted the tank needs to move to get to the loom.
Nope - I'm still on the standard 1200 bars, which I find really pretty good - not too wide and nicely positioned (for me).
The only gripe I have is that they are angled back quite a bit - this causes pressure on the outside edges of your hands which can make them ache a bit. I dont normally notice it, but every now and then I do - not enough to make me actually do anything about it being very lazy and all.
I think this is the main ergonomic reason behind Ricardo Kuhn's Ricky Bars - I remember reading about the same pressure points on the outside of the hands due to the angle of the bars. Ricky's setup provides a straighter bar which suits the hands better, along with risers to put the bars the right distance from the body.
Fitted the 1150R bars at the weekend, and today is my second day with them. Took about 2 hours to fit, the fiddliest bit being splitting the heated grips block connector under the tank, so the wires cound be pulled through the bars. Other than that, a straightforward swap, with no hassles fitting the heated grips and bar end weights, as the 1150 bars have holes in all the right places.
First impressions are that the bike is smaller. The bars are only about 1" narrower each side, and about 1" lower too, but it's suprising how much smaller it feels. Day 2 and it feels less alien, and I am getting through smaller gaps than I would previously been able to get through. Just got to keep an eye on the pots down below. Seem to be more relaxed on the M-way too, as I'm not sitting up so high in the wind.
All in all a good improvement for my purposes, well worth the effort.
