Aidjay
I've got some front brake issues on my R1150GS ADV that I need help with in diagnosing (and hopefully) fixing the problem.
Bit of background - The bike has done 36000 miles and brakes are ABS, I bought the beast about 5 months ago. I don't know if the pads have been replaced before I bought it. The front brakes work fine during normal use (no juddering at all), but while not braking (and coasting while not in gear) I can hear the pads "scraping" the discs intermittently. When the bike is on the centre-stand, the front wheel doesn't run free, it seems a bit stiff. It started fairly recently and can't really be attributed to any occurrence such as a drop or knock (that I know of) etc. My questions are:
Are the discs warped? And if so how does this happen?
Are the calipers not springing all the way back releasing the pads from the discs?
Is it dangerous for me to be riding with the brakes in this condition?
Should the front wheel be running free when on the centre-stand, or is a bit of resistance normal?
Would I need to replace the pads and the discs? Can discs be "repaired"?
Roughly how many miles would a set of brake pads last during regular road riding?
Lots of questions I know, but any help would be most appreciated!
