Marty
Hi 'ukgser' communit! (it's been a while!)
I've lost me horns!
And I'm just about frazzled and out of ideas, having been tinkering away all of today.
I think the left hand switchgear horn switch is duff. However, all other switches fine on that side.
The bikes a 2002 single spark with the twin Bosch horns.
What I've tried to check
I have a 12v supply at the fuse and relay. Have swapped the relay, nothing. Also the fuse is good.
The horns have the 2 wire cable feed - brown (earth?) and green/grey (live) with the tiny recessed pin socket connectors. I've tried to check for a 12v supply between either of the female connectors and battery earth, but cannot get a reading.
Have dismantled switchgear, overdosed it on contact spray and reassembled, still nowt.
It looks like the live feed from the ignition switch goes to a junction block up under the left hand side of the instrument panel and the horn switch wires also go to this block??
I'll be damned if I can get my mitts in there to separate the terminal block and check for corrosion.
The cable sheath that houses all ignition and other wires along/under the support frame in front of the headstock is cracked/perished, but I cannot see any obvious broken/bare wires!
What have I overlooked or failed to check?. I only have a multimeter to hand (no test lamp) as away from home.
Thanks in advance for any pearls of wisdom.
An internet search hasn't thrown up anything close.
Marty
I've lost me horns!
Marty
