DeanV
Mine was doing a similar thing but not to the same extent. I generally use mine daily and it is fine. Recently with a wife about to give birth I have started working from home and 3-4days without use it was almost impossible to start it.
Replaced battery thinking 13 plate the battery is old and well done, how wrong was I.
It turned out to be my Biketrac causing the issue and the fact it was polling 6-8 times a day and the poor phone signal in my garage. It was taking so long to send the signal the unit was draining the battery, never anything major as it never tripped the low battery alert, but enough to stop the old girl from firing.
Quick call to them and they diagnosed the issue as above and made some changes and hey presto , bike still safe and now well charged.
I guess short version, unlikely to be the battery or the stock bike, it's going to lie in the accessories. If really is the bike, I'm going with the canbus not shutting something down correctly
Hope they find it and you can share the outcome.
Good luck
Good luck
