1200GS Lights and H/Light Guard
Camo Jo
South Africa
This Head Light/ Oil Cooler guard and Spot Lights with Brackets are made in South Africa.
What do you Guys think?
looks good. And looks like it would avoid the probs some have had with light being reflected up at the rider at night.
contacts?
An excellent looking piece of kit but does it come as just the headlight protector without the oil coller part?. I bought one of the velcro attachment ones through a link on this site and it fell off! Do you have any prices or contact details?
More Detail
Aplogies, Had to go ride a bit,
1. The Head Light / Oil cooler guard is one unit. (3mm Alu Anodised Black with Poly Carb Lenses.
Sells here in SA for about £63.00
2. The lights are not Hella, they take normal H3 globes. It works qutie well. A dedicated Relay Unit was also developed to enable connection to the existing wiring harness just behind the 1200GS Main Beam in order to activate the relay when the main Beam is on. Does not affect the on board Computer at all. (Tested it with the local dealer)
Also avalable for the 1150GS/A .
Both Kit's come complete with brackets, wiring harness and lights.
Sells here in SA for about £ 100.00
We are currently negotiating to set up a distributor in the UK.
Will keep you updated.
Also make quite a couple of other goodies: Wide Foot Pegs, Gear Lever Extension, Brake Lever Ext, Side stand base and busy developing some more.
