1200gsa auxiliary light security
MickF
Ireland
Just looking for suggestions or products that can be used to properly secure my auxiliary lights on my GSA. At the moment it's too easy for some genius with a 10mm spanner to walk away with them. My mate lost both his recently on a European trip and I don't want to end up the same way.
:aidan
either round off the bolts so a spanner won't fit or a few years ago I fitted a replacement nut onto an exhaust can hanger, it needed a special key to fit it. Or even cheaper is changing the nut and bolt for security allen/torx heads, just makes it that more difficult for the opportunist
Got it sorted. I fitted a lock nut on a torx bolt in the centre of the bracket that the lamp is mounted on. You need both a torx head and a spanner to remove the centre bolt. I also replaced the outer bolts on the lamp with lock nuts. It means that it takes a lot longer to undo the lock nuts and bolts wheras the original set up only required the loosening of a 10mm nut. Hopefully if someone toe-rag wants them at least he will have to work to get them.
:aidan
