1200GSA make it a leetle shorter!!
ianran
Here and there
OK I am on standard seat and shocks but am on tip toe with no luggage, I like seat to pegs ratio so dont really wanna lower seat.
Whats the most cost effective way to reduce height by about an inch or so?
As Podge said to Rodge ....discuss!!!
PS most my wedge (and wifes patience!) went on bike !
Have the seat reshaped to reduce the width. This stop your legs from splaying out when trying to put your feet on the floor and should help by an inch or so. Someone I'm sure will be along to recommend a re-upholsterer soon!
If all your pre-load is wound up already, I guess you could swap your shocks with a GS - they raised the GSA about an 1" over the GS IIRC.
Mike
Convert it to motard spec with smaller wheels? :nenau
Could always let all the air out of the tyres. Won't handle very well but should drop it about an inch (he said unhelpfully). :D :D :D :aidan :aidan
Should be alright coz tyres will only be flat on the bottom :D :D
Cheapest way.....
Slacken off the rear preload and make the suspension softer.
and/or
strap a breeze block to the carry rack!
Other options will cost you money... how much do you want to spend?
Could buy platform shoes too, I here they are coming back into fashion anyway.
shock swop
hoggey in the fir sale section is wanting somebody to swop there shocks with a std 12 pair!> worth a look??.
change ya shocks to a 1200gs shocks..........that will lower it enough for you......without choppin the seat............sorted..
I may have the wrong end of the stick here BUT...
When I buy a bike, or a car for that matter, one of things that determines whether i buy it is whether it fits my physical dimensions - if it doesn't I wont buy it. :confused:
Seems to me all this talk about raising/lowering is missing the point ::rolleyes: I'd have thought the best course of action is to buy something that fits in the first place. For example the R1200ST has a much lower seat height :D
Surely no one would buy a car if they found that the roof height meant that their head was permanently hitting the roof and then so conversely nor would I buy a bike on which my feet couldn't touch the ground...
:hide
Peter
ampthill - you are right, up to a point. But bikes aren't the same as cars ( unless you're an out 'n out car freak).
If you'd like a GS and you've got Ducks Disease, you could get a 650 GS, but if you want a 12GS then the only solution is to somehow lower it.
Where's the problem with that? Give the man a break!!
Phil
Phil
yeah isnt it bad enough the poor chap has Ducks Disease!!! ;)
I've got to agree with Phil here, you like what you like. Just because it isnt perfect for you doesnt mean you want it any less. The same is true for cars, but the beauty with cars is that most things are a lot more configurable.
:hide
Peter
1) Pete, my feet touch the ground for normal road riding however Id like to go off-road and would like to be a bit more flat footed. (should have joined the police!)
2) I considered an ST but doctors found I still had a pulse:D
3) Car roofs? depends on thr car!!!
Each to there own old son, :rob
Lots of people buy completely unsuitable cars for exactly the same reasons that bike people buy unsuitable bikes. Simply because they like them and can afford to take the chance. As a car fan also I keep the odd eye on the cage world. Re heads and roofs, take Jeremy Clarkson as an example. He is so tall that he couldn't close the door on the Ford GT40 due to its roof height of 40 inches. Didn't stop him lusting after one though. As soon as they built one that he thought would fit, the Ford GT, he bought one. Didn't really fit him and he couldn't get to work on a full tank of fuel, but he bought it anyway. :o
How suitable are all the Chelsea tractors on the school run? They only off-roading 99.99% of them do is bouncing up onto a particularly high kerb outside the school to drop off Darragh to his fee paying school or negotiating the gravel to drop Sorcha off to pony camp. :blast
Suitable? I don't think so. Freedom of choice? Absolutely. Now where did I put that soapbox? :D
