12v socket repair help
Hairnet600
nw england
have cradle for quest but the end into the socket the top came off (screw on) and the innards are no more
where can i get it repaired??
thanks
id pic it but i cant find it :blast
Is it the Garmin bike cradle-n-charger you're trying to describe as the circuitry was in the cradle as I recall :nenau
yessir
its this
the top of mine is missing and theres nothing for the pin you see there to connect to
sorry if i wasnt clear :blast
ta
Mark, will the tip of the charging lead screw out? On some leads it will and there is a fuse and spring in there, you might be able to bodge a repair from another lead.
yessir
its this
ta
That's what they called the car charger, with the speaker and transformer gubbins in there.
New ones nearly 50 quid
or 37 quid chinese copies but if you go through the second draw down in the kitchen, you'll probably be able to salvage some bits from other car chargers and bodge up a fix :thumb2
If it is the car charger then I have a spare cradle with plug attached you are welcome to. Might go out for a ride in the next couple of days and could drop it off
this is why it no worky :blast:blast:blast:hide
If Kritou can't sort you out, PM me........I have one of these that I will be using again from time to time, but I'm pretty sure I can frig up an alternative end-arrangement from odds and sods.....I must have a dozen car type plugs sitting around in odd boxes and drawers from over the years :thumb2
