Anyone got a bodge to remove the bearing shell from the top of the steering tube?
As the K1 onwards frame is beefed-up, there's a reinforcing section of tube inside and just below the shell. Whereas with the older bikes you can just knock the old shell out with a long drift, the added metal means that an internal bearing puller seems to be the only obvious way and I don't have such a thing.
There are some cheap pullers out there that would probably do for the few times that the job needs doing but none that will cope with a diameter of 50mm, the ones that will are more money than I care to part with for such occasional use.
