2 power sources required
Afmuir
Edinburgh
Hi, I have 2018 Urban G/S. I want to power an iPhone on the bars and a cigarette lighter port at the rear rack. Ordered a Quadlock mount for iPhone.
Any suggestions for how best to drive these two locations? Want to keep in canbus so no direct battery connection if pos.
Thanks.
Look up GPS wiring on U/tube there's a plug socket on the right hand side of the tank you maybe able to use. Just buy a plug from Ebay about £10 which should give a power supply.
It’s on the left hand side, forward of the auxiliary socket and as it’s cable tied to the frame it’s not easily noticeable. It’s also quite small and has a waterproof plug you pull off. Nippy Norman sells the corresponding socket with two bare wires.
Thanks all, I’ll check there
As paul mentioned, there is an extra plug , it is accessible without moving the tank,
I have my gps mount plugged into it,
