2008 GSA Brake lever.... bit dropped off!!
claw
Durham
As you know the brake lever has that adjustable part fitted so that part of it can flip in and out of it when the spring is depressed. Just noticed tonight that mine was just hanging on.
It looks as though a circlip has come off somehow :nenau
Might be worth checking to make sure yours is well attached, not loose or corroded.
I've attached a couple of photo's to make it easier to show what i mean.
... and yes i know the living room carpet needs a hoover :)
Could probably source you some circlips from work,if you or someone could give an idea of pin diameter,looks about 6mm at a guesstimate.
I'll measure it tomorrow, as its been been put to bed for the evening, i would say its narrower than that though, maybe around 5mm.
