Hi
Last night I attempted (!) to fit a new rear brake disc and pads to my F800GS. The disc replacement went fine but I hit issues getting the new (EBC) pads fitted - essentially the inside pad doesn't fit in the correct gap due to the caliper being slid to the outermost position. The bad news is that the sliding mechanism that adjusts the caliper position over the brake disc appears seized.
The rearmost caliper sliding pin looks to have some movement but the front one does not.
So I have two issues I would love some advice on:
- Any tips on getting that front sliding mechanism freed up - or on getting the rear caliper apart in general?
- Any tips on getting the rubber boot back on the rear slider assembly..i.e. through the hole and back onto the caliper sliding pin..
Appreciate any advice you may have..
