2610 "Map Storage Error" problem
cookie said:
is this why i'm getting this error message when i try & download routes from my PC to the 2610 d'yer think?
Cookie, This problem has cropped up before (I had it myself), see
http://www.ukgser.com/forums/showthread.php?s=&threadid=42209&highlight=*calculate*
To save memory on the card, I had only downloaded 1 or 2 local maps - to leave enough room for Northern France etc. When I returned, and used tha unit locally it turned out that the new routes I had created, had gone off the downloaded maps. If the 2610 has a "simulate route" option, try that first as I wouldn't be suprised that you find that the route you have selected, has taken you off the downloaded maps. Either that, or for some reason the relevant map hasn't been downloaded. I just used the "Select maps around route" option and I've neven seen that message again. Hope that is some help. ;)
this seems to have been the problem. not sure why, but it's working now.
new map set downloaded in the prescence of personal gps guru & it seems ok.
didn't do anything different AFAICT. now i know how it feels when i do something on other peoples computers & when it works they start wailing "but i've already tried that & it didn't work" :rolleyes:
