Just follow the instructions, any problems - do a search on here because no doubt someone has run into the same thing before.
Like any good gadget they're simple enough to use but a little trickier to master - again there are plenty of hints & tips on here.
RAM mounts are very popular, either fixed to the bars or to something called a MigSel mount (fits around your speedo) - again the search button is your friend - with the GPS fitted to either a Garmin cradle or a RAM cradle. If you're feeling flush then Touratech do various types of cradles too.
Being older technology 2610's can't use the Garmin POI Loader (Points of Interest) but you can get a speed camera map overlay.
Main tip is that when your GPS is hooked up to your pc remember that when you download new maps it will overwrite all existing maps on your GPS. DAMHIKIJKOK
Good luck & have fun with it
