2D view from 3D view
GB.
Redneck Norfolk
A tip I found is when using the app to navigate it is in a 3d view regardless how much you zoom out, but you can trick it into viewing it in 2d with a few clicks of the wheel. Using the wheel select route preview, then select entire route it goes to 2d mode and you can zoom in using the wheel but only for two or three clicks before it switches back to 3d view. This can all be done on the fly.
Thank you.
I must have used the wheel as you recommended above but without realising, as mine switches to 2D within two or three clicks up from zoomed right in’s 3D view.
I can never see the point of 3D view, as it just clutters everything up. This is especially true here in London, for obvious reasons. Having the ability to turn it off entirely, as you can on a Garmin device, is something I have recommended to BMW.
