2ND gear broken?
  • Thread starter Thread starter MikeL
MikeL
1997 F650 in second gear at speeds 25mph plus tends to stutter like im out of fuel,the problem is getting worse now in that it goes into neutral if i dont change up straight away Its obviously a gearbox fault but id like to know is it likely to be an exorbitant repair or merely very expensive
If anyone has any similar experiences or can offer me any advice it would be gratefully received
Not trying to push you away or anything................:)
You may find a better response here..... http://www.f650.co.uk/
Sounds like short shifting is required to overcome the problem, or a cash injection.......:(
Best-o-luck...
CC
:cool:
Trevor George said:
The "second gear problem" was a fault which happened on *some* F650 bikes and there's some more information about it (and how to deal with it) courtesy of the "Chain Gang" FAQ pages at http://faq.f650.com/FAQs/Gear_Shifting.htm
Cheers ... Trevor, Bristol, UK.
F650 website dedicated to UK & Ireland owners
Thanks for that Trevor having seen that it means about 10hours labour i guess id better keep on doing what i have been ie thrash it in first then double shift up to 3rd
