MickyBlueyes
Looking to upgrade from an early NetgearReadyNAS DUO v1, which is limiting my expansion, so looking for a 4 bay most likely, and looking for suggestions as I'm stuck between a Synology 413j, and the Thecus & Qnap alternatives. Not looking to spend more than £300 (empty) really.
Currently using 2x WD Red HDD's of 2TB which will be reformatted and added to in the new box.
It's for home/SB use which is run from home, 2 Macs, 1 PC, iPad, Android phone, & a blackberry (although this isn't critical). I would like to move away from another ReadyNAS as I find the software a bit clunky, and restrictive in it's add ons.
Needs to be Time machine compatible, & serve an iTunes database.
Any experiences on set up, reliability, and software support/improvement would be gratefully received.
TIA
Mike
TIA
Mike
