4 stroke engine doing strange things
karlp
Southampton, England
I have a 4 stroke engine that I am rebuilding, however the valve timing marks are a little hazzy.
When I turn it over the carbs blow out instead of sucking in and the exhaust sucks in instead of blowing out - ie it it just as if the carbs and exhaust should be connected the other way round.
I am assuming the valve timing may be out by 180 degrees - any suggestions.
thanks
karl
Daft question but are you sure your turning the motor over in the right direction :D
I had thought about that - but the motor is electric start so is turned when pressing the button.
karl
Giz a clue, what engine is it ??
I've got loads of miniature engines plus I've a lot of single cylinder tech manuals..
Remember golden rule is Crank goes round twice to camshafts once, so it could be 90 degrees out not 180
It is a kawasaki z650 engine.
It does spin the correct way on the starter.
I do think the timing is out but wanted to check other peoples opinion first.
thanks
karl
NO 1 PISTON AT tdc - use a pencil in the plughole and check the timing marks on the crank.
inlet cam faces outwards at 90 deg and exhaust is pointing 180 deg away.
use the nearest timing marks on the sprockets.
If this doesn't work-you'll need a degree disc and first principles - or a clymer manual :thumb
as you were doing a rebuild, make sure you didnt get inlet and exhaust cams mixed up, also double check your valve clearance to be sure they are not tight.
ALWAYS turn the engine over by hand with the plugs removed before turning over on the starter, then you will be sure that the pistons are not going to clip the valves :augie
cam timing, check u aint 180 out and that u use the CORRECT MARKINGS on the cams, there are different ones, difrent models
wen i was doin my gpz i made novice mistake wen setting cams, they wer 90 out , i forgot that its two turns of crank to one revelution to the camshaft followers:blast
thats the one!ur learnin:thumb2 180 out
thanks for the repliers
The inlet and exhaust cams are not mixed up - there is no way that can be done as the exhaust has an rpm driver wheel on it.
I did check theat the engine would turn by hand and all was ok.
valve clearances have been checked and double checked.
I will check that it is not out by one cycle as that is my first thought. - probably on week end then report back.
thanks all
karl
