60CSx software update to version 3.60
ebbo
York
Changes made from version 3.50 to 3.60:
• Correct German translation of 'delete all waypoints'
• Fix data card unlock failure when 2 cards of the same map set are used in one device
• Improve sun times for polar regions
• Fix issue where ETA in non motor vehicle modes can be unreasonably short
• Improve robustness of compass when it would appear uncalibrated until a power cycle
• Increase precision of distance measurement to the cursor on the map page
• Allow backlight adjustment on the track back point selection page
• Fix shutdown when editing Estonian Grid coordinates
• Correct daylight saving time for New Zealand
• Improve selection of the names of cross roads with NT maps
• Correct potential shutdown when viewing a vertical profile
link to download below
https://buy.garmin.com/shop/store/downloadsDetails.jsp?id=1245&product=010-00422-00&cID=145&pID=310
How are you mounting your 60? I`ve tried mounting mine on the left hanlebar but it fouls the hyd. resevoir and tank on full lock using the Garmin handle bar mounting kit.(1200GS)
Thanks for your help. Mike
I have the Ram mount and the Garmin cycle mount but haven't mounted the 60CSx on the bike yet, reason being the Ram mount has a death like grip on the 60CSx, it took me 2 days to finally summon the courage to prised it free from the bottom :mad: I'll need to attack that one with the dremmel before I try it in again.
As for the Garmin cycle mount, well, it would help if I could find it :blast but from memory it had nearly as deathly a grip as the Ram :(
