650 Dakar foot levers
Flipfly
Stoke on Trent
I need gear change and rear brake levers that bend at the ends. What options are there other than the £200 :eek::eek: option from TT????
I don't want the pegs as I already have them :blast
Why? Levers are steel and bend easily anyway. I never had any problems on mine and the BM Off Road course bike I rode survived a couple of "rebends" :augie
I bought the TT gear shift and it's "half a spline" different to the BM one, which worked well with off road boots.
i bought the same as spout for the gearshift, folds at the end and is better than the stock lever.
the brake lever is 01-041-0702-0 (stick it in the search box) and its £32
Why not try a folding lever from the x challange, its basically the same engine, just with a few more hp, so the splines should be the same.
there's two options one at £30 odd that requires cutting up the existing lever at one at £60 odd
cheap version is 01-049-0223-0
expensive version is 01-049-0223-0
I'd go for the cheap version, all it is is the actual tip of the lever, the bit that folds. If i were to buy one i'd grind off the existing serrated foot bit of the brake pedal and bolt the tt bit on in its place, easy to do.
In fact, i've just ordered one :blast
i got my cheap(ish) folding lever bit from touratech, fitted and working :thumb2
All for £35, cheap for touratech :clap
£35 for that :blast:blast:blast
Looks really nice and you've done a great job, but there is no feckin way I'm giving that robbin' bunch of Twots £35 to do the same.
