Easter greetings!
Just changing front pads and found that the caliper is no longer floating. The piece that connects the caliper to the fork (caliper bracket?) is only connected in one place - the top floating pin (there is a second lower one however this is merely a pin with rubber cover so zero chance of sticking)
My question is - can this be hammered through or will this just bend the slider? Also heating - i'm presuming the assembly is fairly heatproof by the nature of what it does, would this help?
Any advice would be gratefully received,
S
S
Hit the bracket side and not the caliper. Make sure you know which way it separates because on the XCh one pin was fixed to the caliper and the other was fixed to the bracket. You will doubt your sanity but it will eventually go ...
