660 Help
Twister
Co. Antrim N.I
Hi,
Have been using Zumo 660 with Interphone F5 for a couple of years now without problems. I recently had to return the 660 for a software problem and got it back. Normally when playing music via 660 into F5 headset and I switch the headset off, the Zumo would have still showed mp3 as playing but there was no sound from the unit. Recently when disconnecting headset from the unit the music starts playing through the speaker of the unit whilst in the bike mount. Is there a way of sorting this out in settings or is this still a software issue
Paul
Hi,
Paul
I think that is what it is supposed to do.
Remmeber that the 660 has a speaker built in to it unlike the NAV 5 so that it could "speak directions at you when in a car mount for example. It will default to its external speaker when not conected to anything else
Mine does that now I have it connected via a BTM02 into my Autocom. Might be worth trying plugging a old pair of ear-buds into the 3.5mm socket in the loom, and coiling these up under the seat, as this cuts the built in speaker :nenau
Might give this a try myself when I have the time as it can be a bit embarrassing pulling up, turn off the ignition and then have music blaring out of the speaker as soon as the Bluetooth disconnects.
