660
paul nicholls
yorkshire
bit of help please,
i have the bmw nav 1v which in essance is the 660.
i had the nav 111 on my last bike, have a nuvi in the car,
both would display your eta for your destination
the nav 1v seems not to.
ive gone through all settings, looked through the instructions
to no avail.
am i missing something?
anybody know how to get it to display the eta?
thanks, paul.
On the 660 the info panels at the bottom of the screen
are selectable, If you touch them then you can choose what to display there and one of the options is ETA.
Not sure if this works on the BMW Nav1 but is does on the 660
HTH
~Jav
I assume your talking Zumo 660, on mine I have, down the right hand side, 4 displays which show 'Arrival Time' etc, to show these settings go to
Tools / Settings / Map, and set 'Map Data layout' to 'More Data View'
Once you have that selected tap back to the main screen and select Map, this should then show four options on the right of the map display. Tap any one of them then you will have the option to select the settings you want to see.
Hope that helps....:D
Spot on :thumb2
Works that way on the Nav IV and the 660, who both share many of the same attributes.
