Malcolm Leick
After 20,000 miles I think it's time to replace the original chain and sprockets on my F650GS.
Given that TT now offer a range of front and rear sprockets would I gain much advantage from losing one tooth on the front and adding one at the back? This would be a similar set up to the F800GS.
I know it would lower the speed a tad, but I'm not too bothered by top speed as the TKC80s keep me to 95mph anyway. Would it make that much improvement to off-road performance and on the down side, would it increase fuel consumption significantly?
90% of my riding time is on-road so I don't want to compromise this too much. But I also want to get into more off-road stuff.
Reading the other threads on chains and sprockets it sounds like a chain upgrade is definitely the way to go. I'm due for a tyre change soon so will probably get it all done at the same time.
If you read this Tim C, what are your thoughts? I know you have done a lot of miles on all terrains on your F650GS. Have you ever considered changing the gearing?
