jtw000
I picked her up just over a week ago. Loving it to bits but I got her cheap due to a few cosmetic deficiencies thanks to the seller trying to paint bits with no clue as to what he was doing! He had painted the side panels and luggage rack blue in an effort to match the alloy covers and had failed miserably. I keyed them with wet'n'dry and repainted with Simoniz "tough black". Quality paint which really does what it says on the tin. I'm letting it cure properly but it seems fairly resilient to chips and scratches straight away, as well as water and solvent. I also made up a simple guard for the oil cooler because it needed one and I had some quality slotted steel just begging to be used.
I fitted a new, cut down screen as the original one blew right into my eyes and had yellowed quite badly. I'm not a lover of the screen but will use it as a basis for making my own unit up. I removed the plastic luggage clips on the rear frame and as i can't identify a use for them I'm not fitting them back on.
It is a little scary modifying such an expensive bike with rattle cans and alloy cut from a cake-tin but it worked out ok. Next is the tail light... that has to go!
http://www.londonstreetbiker.com/yabbfiles/Attachments/P1030492.JPG
The plate was bent to fit the bottom of the cooler and the shroud was cut from a cake tin and sanded by hand before being buffed on a polishing wheel. It was easy to fit and looks a million times better than the scruffy and vulnerable oil cooler.
http://www.londonstreetbiker.com/yabbfiles/Attachments/P1030494.JPG
From the front it hardly notices really but is still a big improvement over standard.
http://www.londonstreetbiker.com/yabbfiles/Attachments/P1030496.JPG
Better...
http://www.londonstreetbiker.com/yabbfiles/Attachments/P1030499.JPG
Before... Close up the paint on the side panels was lousy with orange bloom effect and overspray that had covered the fixing screws. I like to be different, it makes it feel more like my bike rather than I bike I bought.
http://www.londonstreetbiker.com/yabbfiles/Attachments/P1030478_001.JPG
Better...
