AAArrrrrrrggggghhhhh - Wireless
Macca2321 said:
Ok,
My IP address is 192.168.2.1
The IP address on my daughters is 169.254.107.96
I am using a dongle and the software that came with it (worked fine before formatting!!!) I am not using windows....
Still :nenau
As per my previous response, your daughters IP address starting with 169 signifies that her pc has not been assigned an IP address by the router (set as a dhcp server)
try opening a command prompt window and typing the following:
ipconfig this will show the current ip address again... then
if it is still showing as starting with 169 type:
ipconfig /release followed by ipconfig /renew
leave it for a minute then retype ipconfig and see if the ip address now starts with 192.
Let me know how you get on with this, or if you've already solved the problem.
hope this helps....
Stu.
