Been searching but dont see the same fault listed anywhere.
This fault is currently very intermittent .
Turn on ignition, dash lights go throuigh startup test, either the red brake fail lamp flashes and goes out after moving forward ( like it should )
or instead of flashing , stays on solid. The abs symbol on the LCD however flashes like it should and also goes out once moved forward , even if the red lamp is solid , but no ABS available .
Checked rear lamps do not have dodgy connections , checked abs sensors as much as I can without a GS911 which obviously work ok when the fault is not present . Battery is good .
Even if the brake fail / ABS lamp does go out after moving , it can come on and stay on at random .
Nearest dealer is 100Km away and closed for all of August which is probably the soonest I could getr there .
Did 500km at the weekend with no proiblems , did 10 Km today and fault showed up 4 times after ignition off and re start .
Anyone got any ideas ?
