I've got an '03 1150 with servo ABS, the front wheel has a sensor ring (mounted to the left disc mounts), the rear sensor mounts into the bevel box and (I suspect) detects the passing of the gear teeth therein.
I fear that doesn't help. since it doesn't look like an answer to your question. But no measurement of my bike would. Were the earlier onews that much different?
For a start you haven't stated the model of bike and the year. They are not all the same.
I'm probably wrong here because I have a Post sep/2002 bike with EVO (servo brakes ) so I am assuming you are talking about a pre 2003 model with solid ABS rings.
I thought the front ABS ring had 6 fitment holes and the rear ABS ring has 8 fitment holes.
just lightly mount what you think is the front one with a couple of disc bolts and (including the disc) onto the wheel and set it into the forks and nip up the axle bolt
if it's around a mm off the sensor you chose correctly and the other one is the rear
