ACC 211137 lead?
bakerlonglegs
Relative numpty
Nottinghamshire
My GSA came fitted with this, between the sensor on top of the air box and the wiring loom:
The white tag says ACC211137. Does anyone know what it does and which company made / sold it?
Thanks!
Yes, I have one on my GSA. They were made by someone in Belgium and it supposed to fool the ECU to run more richer whereby addressing the problem of popping when having a performance exhaust with no CAT and K&N filter fitted. Normally modern day bikes run towards the lean side.
sol2be
To the best of my knowledge is the name of the company that does them.
Sent from a OnePlusX
It's an accelerator module. Works great at soothing out low speed lumps
Sent from my SM-G920F using Tapatalk
Simply a thermistor and maybe a resistor providing a negative temperature offset to temporarily richen the mixture.
The module will have an effect for the first few tanks of gas then Motronic MA2.4 (1150, 1100S) compensate back to stock settings.
