Acewell or Similar ? fitment
the civil one
Donegal , Ireland
I am looking into an Electronic Speedo &.tacho for my R65 {84 }
HAve any of you fited and acewell or similar , how simple was it to fit :rolleyes:
I'm going to be fitting one myself. Are you using the gearbox pickup Phil?
Thats the crack Rob , I dont know . Do you just use the Gearbox pick up on the Acewell ? and then "Dial in the ratios " ? My idiot lights are all wired thru the Rev counter , ?. Then i read on Adv that the Gen light causes issues ? .. I just dont want to open a can of worms, i cant sort my self.
I am After a Plug and play for monkeys ,,solution.
Flatracer have one , but its small and It £269 of yer finest ! ..
But i need to make room for a bikini fairing..
Civil,
I put Vapor Tech on a friends CCM, and it was quite easy. We used a special bolt which had a magnet glued into the end, on one of the disk bolts. The sensor supplied was glues and cable tied to the inside of the fork leg with about a 2mm gap.
Its worked finr for over 2k miles so far.
The Acewel units can be run similar, or using a electronic drive box off the standard speedo take off. The team a Acewell are very helpfull if you drop them an email.
HTH
Neil
Ive got a acewell on my airhead
It's been onthere for a while now and seen some rough conditions
I have had no problems at all with it
Just make a good job of the speed pickup...thats the weak point with any of these devices
You don't want the guy who wired this fitting it
That looks like a really well sorted installation - got any more photos of it for "inspiration"
Sent from my GT-P7500 using Tapatalk 2
Guten Tag ,,
Well i didnt know the germans gave the Neterlands Back ,,
To Much amusement , Matt , at Boxertoko , reckon i sounded Dutch
with my Eloquent , and Educated tone , Much to my Amusement !!!
I explained my Quandry , i had a 0% confidence i my ability to fit an
acewell , but want one.
I told him of my " Sensitivities " which he had sympathy for .
I took a few photos of the wee R65 showing the Wires i had ..
OK , Says he , I will make you a Plug and Play Loom .
Top Marks ,,, Boxertoko ,,:clap:bounce1:clap:bounce1:clap:bounce1
http://bmwboxersupplies.com/
Sorry to resurrect such an old thread, but did you get your acewell 'plug and play' loom from bbs, and how much did it cost?
I did get it sorted.
With a Massive amount of Help from Matt at : http://www.bmwboxertoko.nl
I had no confidence in my Electrickery Skills , and i relayed this to Matt .
He asked what i had , I told him , Photographed it , and sent him as much detail as possible .
He sent me back an Acewell Unit with a mini loom he had made for me , so i could simply pug it in .
I did it worked , everything ,first time. No messing. Top Fella , he did what ever extra work for no extra cost
i paid him Eur191 + Post.
IF there is a man in the BMW Airhead world ,From my experience , i could hold my hand on heart and say
HE is a GENUINE Fella. Then it is Matt Beekers . No Question.
i fitted an acewell a couple of weeks back. might even have a diagram of how i did it somewhere :)
