Adhesive velcro peeling off
Rugged Path
The Honourable.
Wybunbury, Cheshire East, England, EU
On my trunk and cases, the velcro holding on the hanging organiser bags are holding on by what remains of the original adhesive glue. But not for much longer.
Either I renew both the hook and look velcro strips or use some proprietary glue from a DIY store as an alternative fix.
Any suggestions?
Sent from my MI 9 using Tapatalk
Look on eBay, you can buy just the hook or just the loop by the metre or yard, all self adhesive :thumb
I've even got some in the garage if you want to be really cheap.
Remove the original - white spirit to remove the glue residual then new Velcro - available online / Hobbycraft when open or Paul above......
Buy 3M or Tessa. Prepare the surface properly. Do not use white spirit . Leaves a horrible residue. Use Isopropyl alcohol (from boots). That combination will give you the best chance of it actually working/ staying on. Personally I'd avoid the cheap stuff.
