Bit bored last night so had a play with the handle bar position on my 08 GSA
The bottom handlebar mounting blocks can be turned through 180 degrees to move the the bars further forward and a little higher - fairly simple job just make sure you protect the tank whilst doing it.
Starting position:
Turning blocks around:
New position:
The manual advises that this should only be done by an authorised dealer and so does not give torque values for the 4 bolts. Does anyone know the correct torque values (2 diferent sized bolts used front and back). Did mine by feel fully tightening the 2 larger bolts which go down into the head stock and then tightening the 2 smaller bolts which only screw into the mounting blocks.
I think that moving the bars will only be of interest to lanky gits like me with long arms
Starting position:
New position:
