Deleted Member I
If the 1200GS loses to that girls' bike then I am selling my bike
If it says it in Bike then it must be true
I can`t believe the Stelvio came last. I had one for a day and it`s a brilliant bit of kit and performance wise, it kicks the sh*t out of the 1200!!
Don`t think the girls bike will ever replace the rufty tufty 1200 though......
Just read the review .. right I am off to the KTM shop.
Get myself one of them 990 jobbies
Have you ever had a motorbicycle or a bicycle with a chain? Make sure you can lube one before you part with your cash
I'd laugh if I didnt think you were serious.
Engine lacked oomph and needed revv'ing, once you got it spinning it was OK but IMHO one of the reasons one buys a big twin trailie is for the mid range and lack of gear swapping needed, the GS ain't perfect but has power where i want it.
Handling wise the Stelvio felt tall and heavy, i also noticed the bike responded to shaft torque at low speeds making filtering that bit more awkward as it juddered from side to side. Suspension was adequate until you pushed on harder where it seemed to lose control, its always difficult to judge on a test ride, it takes time to adjust to a new bike and as its not yours you ride it a bit differently but i felt it didn't inspire confidence on bumpy B roads where it ended up "bouncing" rather than damping. The GS doesn't give a lot of confidence in its front end at first but it did feel more sorted and in control.
Stupid little things htat didn't seem sorted, the gear lever was positioned so that your inner foot contacts the lever all the time, you almost rest on it, it might be possible to adjust it downwards but then you'd need a more sportbike position to hook your foot under. paint chipping off bash guard with no miles done, overall finish not good.
I've owned 2 Ducati multistradas prior to the norge then GS, the Stelvio is more road orientated and a closer comparison should really be with a multi or tiger, they all share bigger road size rear wheel and don't have off road capability, suspension travel and ground clearance would probably limit the Stelvio.
So, IMHO the Stelvio sits somewhere between a multi and a GS, if you want a tall bar road traillie with a shaft take a look at it, but if you aren't bothered about the shaft I'd take a multistrada every time 50kg lighter and way, way better handling.
Stelvio v's GS I'd say the GS is more refined and finished, maybe a bit bland because of that in which case a Stelvio may be worth a look at if you want different. My experience of Guzzi hasn't been good with the Norge though, QC sadly lacking and bikes suffer from a variety of faults, with the GS one knows there are "quirks" but you can prepare for them
I have read that in order to check the oil level on the Stelvio you need to remove a plastic piece of the fairing
