I've recently bought an Adventure tank for my standard GS.
Firstly the studs holding the pump/filter plate are half knackered.... I can space them out with washers so the nuts go on the best section of thread, but would be happier if the studs were 100%. Can they be replaced?
Also, I don't think the internals are Adv originals, as the two overflow pipes are very small diameter... smaller diameter than the ones on my 2001 GS anyway so they won't fit on the plastic connectors. I can always use the internals from my own 1150 tank ( which are in better condition anyway) Is there any reason (technically) why my 1150 internals won't work?
Would appreciate some advice re: the studs.
Many thanks
Will
Many thanks
Will
