Non ABS bikes have more feel and modulation. My ABS servo jobbies are a bit wooden 'much less obvious feel' but you get used to that. Anyway it's fun to play in the gravely bits.
If I was looking to change tyres, I'd be looking at the Tourences. They seem to be very good all round tyres with an excetional ware rate. I used to run on Anakees, getting 11000mls from a rear and 16000mls from the front.
Changed them for TKC 80's back in May. I'm well impressed how good they are both in the dry and the wet 'they do what I want them to off road too'
I've sofar managed to get 9000mls from the pair and expect to get aproximately 11000mls from the rear and god knows what from the front.
Most of my riding 'to be honest' is in town following trainees. But you've only got to look at my 2mm sissy lines to see just how good the things are. The feed back is very good, cornering in the rain they will let you know when to stop pushing. You can feel them starting to walk (if you get what I mean) you don't realy get that with a conventional modern tyre 'grip, grip, grip gone springs to mind' the TKC will tell you when it's time to back off.
You can guess what I'm going to be riding on this winter
Wonder if I can get 20000mls from the front? afterall they say you use two rears to one front with TKC 80's
