commandoallan
Evening All,
Just had a major day servicing my bike and also removing the old ESA units in preparation for fitment of a reconditioned pair of Ohilns (non ESA) in a week.
Carried out the valve clearances on the left cylinder with no issues, started on the RHS and the 2 no intake were fine but the 2 no exhaust were very tight indeed with absolutely no clearance at all. When I slacked off using the allen key the springs just took up the slack rather than leaving the little gap as the other valves had at the start. I looked at the design of the fixings and started to slacken off a couple of the fixings and tighten up another star drive fixing at the back slightly in an attempt to give more play at the front....Then re tightened everything again
Probably f...ked it right up now and may be in for a surprise at the end of next Monday when I start it up and take it for a ride.......
Any advice before I actually start it up again next Bank holiday would be welcome......
